TwinTurbo.NET: Nissan 300ZX forum - or it is off one or more teeth on the crank sprocket
aliaZ
on July 26, 2012 at 3:49 PM
If the compression readings are accurate then I'd say
posted by Evan_Wright (Ca)
on July 25, 2012 at 09:52 PM
car won't turn over
ouikikazz
13:53:15 07/25/12
So what you're really saying is the car will turn over.
Draker (Eugene, OR)
14:22:49 07/25/12
How do you know you have fuel?
AHos(Chicago)
14:43:07 07/25/12
Re: How do you know you have fuel?
ouikikazz
15:22:38 07/25/12
Only 4 things to make an engine run..
Drunkpunk082
16:41:09 07/25/12
Re: Only 4 things to make an engine run..
ouikikazz
16:54:45 07/25/12
One more thing about the EFI harness...
Drunkpunk082
10:15:03 07/26/12
ouikikazz
19:29:56 07/25/12
Re: Re: Only 4 things to make an engine run..
ouikikazz
19:49:48 07/25/12
Is your fuel pressure regulator plumbed correctly?
Evan_Wright (Ca)
21:47:06 07/25/12
Re: Is your fuel pressure regulator plumbed correctly?
ouikikazz
13:16:46 07/26/12
did you crank forever to start it (mpi fuse connected) then
ztunerz
22:15:04 07/25/12
Evan_Wright (Ca)
21:52:08 07/25/12
agreed (n/m)
ztunerz
22:11:56 07/25/12
3rded (n/m)
Antihero
09:37:16 07/26/12
I bet my money on this. (n/m)
Drunkpunk082
10:12:54 07/26/12
Re: If the compression readings are accurate then I'd say
ouikikazz
13:21:17 07/26/12
or it is off one or more teeth on the crank sprocket -
aliaZ
15:49:39 07/26/12
Re: or it is off one or more teeth on the crank sprocket
ouikikazz
16:42:53 07/26/12
it is unlikely that you pinched all 6 injector o-rings
aliaZ
16:46:38 07/26/12
Yes, pinched o-rings don't explain the compression results.
Evan_Wright (Ca)
18:07:35 07/26/12
Re: it is unlikely that you pinched all 6 injector o-rings
ouikikazz
20:55:28 07/26/12
that would explain your low compression numbers
aliaZ
08:58:05 07/29/12
i win (n/m)
ZiNnYc
17:19:15 07/29/12
